Most likely an easy question but, Im using Virtual DJ to stream over internet radio, and I cant for the life of me figure out how to add in voice overs with a microphone, I dont see any support for a microphone in the interface... am I missing something?
(second question, why does it say No license user under my name?)
geposted Mon 10 Aug 09 @ 7:04 pm
Hi kyronami,
can you tell me what equipment and VDJ version you use?
Soundcard, PC/Notebook specs and so on.
You found your VDJ Version Info under Config -> Info
Your second question is easy;-)
You have to register your valid licence of VDJ at "MODIFY MY PROFILE".
Then you are not longer a No Licence User ;-)
See you
Haui
See you
Haui
geposted Tue 11 Aug 09 @ 1:14 am
I am having the same problem. I am using a simple microphone with Cue Version 6.0.2. I have a Intel Pentium E5200 CPU and an NVidia GeForce 9400 GT. I have tested the microphone and it works fine. Can anyone help please?
geposted Sat 05 Sep 09 @ 7:59 am
I am experiencing the same issue. Set up: MXL USB .008 Condenser Microphone, Creative Sound Blaster X-FI (soundcard), OS = VISTA ULTIMATE on VDJ6.0 Basic.
geposted Wed 09 Dec 09 @ 10:11 pm
geposted Wed 09 Dec 09 @ 10:12 pm
