Hello!
I recently bought a hercules MK2. I have a mac running VDJ and I usually also use the MK2 on a PC (just for fun) and every time I do the drivers need to be reinstalled. This weekend I did what I normally do for this, and this time it didn't work all the way. The lights turn on and nothing happens. It doesn't get recognized by the computer and I am not sure what to do. I tried reflashing it while holding down the talkover button (as many forums have suggested doing) and nothing happened. Everything I can find says to call Hercules to get it replaced or fixed, and I'd love to do that, but I cannot find a working phone number.
I am wondering if anyone knows how to fix this problem or has a working phone number for technical support
Thanks a lot!
Thanks a lot!
geposted Tue 11 Aug 09 @ 2:52 am
Here we go ;-)
http://ts.hercules.com/eng/index.php?pg=contact
What vdj version do you use on your PC? The Limited Edition?
Did you already installed the latest Hercules driver?
http://ts.hercules.com/eng/index.php?pg=files_faq
Haui
Haui
geposted Tue 11 Aug 09 @ 3:51 am
Try these procedures ( PC or MAC, depending on which computer you decide to try them on):
PC:
http://ts.hercules.com/faqs/eng/her_eng_00386.pdf
MAC:
http://ts.hercules.com/faqs/eng/her_eng_00387.pdf
PC:
MAC:
geposted Tue 11 Aug 09 @ 6:52 am
I tried and failed. It is still unresponsive.
I also tried calling the US number, and it does not work.
Does anyone know what may be happening, and why the tech support number is wrong?
Thanks again!
Thanks again!
geposted Tue 11 Aug 09 @ 12:21 pm
At which point during the procedure did it fails ? Did you get any error messages?
You can always try the Canadian number instead.
geposted Tue 11 Aug 09 @ 1:19 pm
