I am using 8th wonder promo website to download mp4 music videos for my virtual dj program. Problem is they wont play or show error on vdj. I am kinda new to the vdj program and I need some assistance to make these two programs work. Do I need a converter program, and if so where can I get a good free one. I would appreciate everyones help on this if possible.
Thanks,
Jason
Thanks,
Jason
geposted Tue 11 Aug 09 @ 11:57 am
For helping you - we need some more informations. Which Version of VDJ do you use ???
Home, LE or Professional ? Version 5.xx or 6.xx ???
Greets, Heiko
Greets, Heiko
geposted Tue 11 Aug 09 @ 12:14 pm
I am using version 5
Greets, Heiko
Greets, Heiko
geposted Tue 11 Aug 09 @ 12:53 pm
So it seems that you have v5.0 ? Because there are many subversions of the program.
Do you have the home, le or professional version ?
Greets, Heiko
Greets, Heiko
geposted Tue 11 Aug 09 @ 12:55 pm
Sorry I have the pro version. If it makes a difference I am using my laptop that has Vista operating system.
Bt the way, thanks for your help.... I'm trying to understand this thing
Greets, Heiko
Greets, Heiko
geposted Tue 11 Aug 09 @ 12:58 pm
I belive this problem is not a VDJ problem.
Have a look to the size of the not working files.
Funny, all have the same size.
Only the files with a bigger size then 37.000 have any content inside.
I don't know, maybe a 8thwonder problem.
IMO, you had to wirte the 8thwonder and ask about it. ;-)
BTW; Keep in you mind, the unofficial versions , are not so stable like the official ones ;-)
If you have a valid licence code, register your version under "Modify My Profile"
So you can download the latest Update Version of your bought software and join also the goodies;-)
See you
Haui
See you
Haui
geposted Tue 11 Aug 09 @ 1:14 pm
I download tons of Videos from 8th wonder all the time and I have never had a problem playing them with Virtual DJ. Make sure your PC has all the required Video codecs installed.
geposted Tue 11 Aug 09 @ 6:21 pm
Mine works fine with 8th wonder. Upgrade your PRO version.
-David
-David
geposted Tue 11 Aug 09 @ 10:00 pm
