HP Pavilion DV9700 Laptop
Intel core 2 Duo CPU T5550 @ 1.83 GHz
4 GB Ram
Vista 64bit Home
VDJ 6.1
H RMX
Every time I Boot up The Taskbar and the bottom on the Desktop freezes
Cant access start menu, or any of the item an the task bar
I can Right select on the desktop but if I was to open any application, My computer, VDJ, Manager. They freeze after opening
If I Ctrl + Alt + Del, and select Task Manager everything unfreezes.
However, there is more. This has been happening for about 3 months now
Will be playing at a gig.. all of a sudden the music stops. RMX light ]s are flashing and VDJ behaves as if the RMX sound card is gone.
I end up running out of the headphone jack the rest on the night..
When I get home the only way to get VDJ to C the RMX as a Controller or a Sound Card is to remove all RMX drivers and reinstall them..
So today I reformatted the drive, (I have done this before to try to correct the problem)
And from the time I finally got to the desktop the taskbar was frozen again..
No VDJ or RMX driver installed yet
Did a complete Windows update but still this is happening
I’ve had this laptop for almost 2 years and this just started happening back in may..
4 GB Ram
Vista 64bit Home
VDJ 6.1
H RMX
geposted Tue 11 Aug 09 @ 2:26 pm
I just figured out when Taskbar is frozen I can access everything with the keyboard but not the mouse. Onboard or usb
geposted Tue 11 Aug 09 @ 4:15 pm
IMHO the processor is not enough to run the 64bit O.S. Also what do you play at gigs? Audio? Video? or both?
Did you upgrade your laptop from XP to VIsta? kinda a small processor for a 64bit OS??
geposted Tue 11 Aug 09 @ 4:29 pm
I run everything on this laptop,, for a year and a half I never had this happen,,, never,,, this laptop has been very reliable, Every other week the sht hits the fan and loose rmx operations. laptop is not running hot all seems good but this
I don't even have that crazy video freezing problem on the laptop
It has 512 ded on the vid card as well.
and as I said. once I use conrol alt delete , it work fine but saturday ..night before MX issue.. the software world freeze.. I used the C+A+D and it worked ..
could something be going bad on the laptop.. Is there a software that will check the hardware?
geposted Tue 11 Aug 09 @ 4:45 pm
It's more likely a software update problem. Check for any installed software or maybe harddisk fragmentation. (Use defrag)
Good Luck!
PS. RAM could do that all time if a memory module is defective. But it give you a blue screen. Freeze is more likely a USB or any other device not found or a malware software on your PC.
geposted Tue 11 Aug 09 @ 5:38 pm
Good Luck!
Good Luck!
Thank you
It stopped freezing one I updated every drive I could find
I was thinking its A USB thing,,
geposted Tue 11 Aug 09 @ 6:45 pm
Good Luck!
Good Luck!
The RMX USB seems to be the issue… I opened up the RMX and the everything looked fine..
What took me back to the RMX was I installed drivers and everything was working great..
Got up today.. plugged it in and the light on the RMX just blinked continuously.. Like before..
TRIED OTHER USB PORTS, a different laptop. Changed the usb cable
geposted Wed 12 Aug 09 @ 12:07 pm
That is a sign that your firmware has not been installed correctly or has failed. You can reset the firmware by following this pdf manaul
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=215&cid=6
geposted Wed 12 Aug 09 @ 12:14 pm
I will check it out thank you
My mouse was giving me issues aswell so u must be right
geposted Wed 12 Aug 09 @ 1:22 pm
its not seeing the rmx still.. light continue to blink
geposted Wed 12 Aug 09 @ 1:58 pm
I'm almost certain it's a firmware issue or a defected unit
Could you try this, try to install your RMX on a PC that has never seen the device before or any Hercules Driver packages. I can remember reading a thread about this. The user did this and her RMX accepted the Drivers and firmware from that PC and it cured the light problem out.
geposted Wed 12 Aug 09 @ 2:31 pm
jimmy b wrote :
I'm almost certain it's a firmware issue or a deflected unit
Could you try this, try to install your RMX on a PC that has never seen the device all the Hercules Driver package. I can remember reading a thread about this. The user did this and her RMX accepted the Drivers and firmware from that PC and it cured the light problem out.
i have one other pc i can try but.. do i need to install the drivers
geposted Wed 12 Aug 09 @ 2:38 pm
i will nee to do this after my gig. thank you
I did conect the rmx to the other pc and the rmx didnt show up in DM
geposted Wed 12 Aug 09 @ 2:42 pm
if this thing don't work by morning i'm going shopping..
geposted Wed 12 Aug 09 @ 3:57 pm
