Hi 2 all
my setup is as follows...
vdj v6/eks otus midi controler /pioneer djm 700 mixer (its midi controler too) and a real powerful pc.....
I am trying to map the otus and the djm together but somehow i cant add the midi of the mixer to tha mapping of otus
in the older versions of vdj its was simple 2 midi controlers worked fine!
plzZzZz help me some one!
Telixx
Telixx
geposted Wed 12 Aug 09 @ 2:28 pm
ps:...adding a new tip
I made a map for this combination in a XML document and works fine in older version
is it possible to load it in the mapping section and how?????
geposted Wed 12 Aug 09 @ 2:57 pm
Older mappings aren't supported.
Are you using windows XP?
The Otus might be one of those controllers that has no unique driver name and no sysexid.
geposted Wed 12 Aug 09 @ 6:54 pm
iiiiiiiiffffff I add or change the eks otus mapper(so I can add mapping of the djm pioneer 700 mixer) that is in My Documents\VirtualDJ\Mappers ??? I see it has many mappers in xml 's how can it be recognized??
PS: yes I'm an xp fan..
geposted Thu 13 Aug 09 @ 4:47 am
Mappers correspond to native devices and definitions in the Devices folder.
Have a read of the wiki :)
geposted Thu 13 Aug 09 @ 12:29 pm
