anyone has a straight link to updating my firmware....................i went on the hercules site, but could not see the firmware link to download ....thanks again
geposted Wed 12 Aug 09 @ 4:44 pm
Think this is what you're looking for buddy!!
geposted Wed 12 Aug 09 @ 5:31 pm
Ummmmm...What, exactly? You didn't include the link.
Anyway, as far as I knew, the firmware is updated when you install the latest drivers. If there is a way to update firmware only, I'd like to know, too ;)
geposted Wed 12 Aug 09 @ 6:34 pm
where is this link....or is it my glasses
geposted Wed 12 Aug 09 @ 6:50 pm
Yep, your right mate. The firmware update is always included in the Hercules Driver Packages. So chances are that if you have the latest driver package installed then you have the latest firmware.
I don't recall Hercules releasing just a Firmware update.
@marlonb
The way to tell, is open up the RMX control panel and go to the "about" tab ( I think ) and the info is there. If you can do a screen shot of it, and I'll check with mine, when I get up tomorrow. I now I'm all up to date with mine.
BTW here is a link to the latest Driver Package.
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=215&cid=1
geposted Wed 12 Aug 09 @ 7:21 pm
I don't believe there was a firmware update between the last two updates (2009_HDJS_2 & 2009_HDJS_3). If you installed the 2009_HDJS_2 update, then you'll have seen the drivers and firmware get updated. When the latest driver update (2009_HDJS_3) is applied, I dont believe this updates the Rmx firmware (in particular if you've installed the the previous update (2009_HDJS_2)).
geposted Wed 12 Aug 09 @ 9:21 pm
Maybe you're right, or maybe one of the firmare updater improvements was "quiet" updating.
geposted Wed 12 Aug 09 @ 10:32 pm
Damm it sorry dude here's the link
geposted Thu 13 Aug 09 @ 2:11 am
ok, so we are all on the same page....once you update your drivers everything seems good
geposted Thu 13 Aug 09 @ 4:30 am
Each driver package always contain the latest fimrware updates files for all DJ Console series product.
Updates will only be performed if, during the installation process, the installer detects that your fimrware is older than the version included in the package. If you already have the latest verison, obviously, no update will be necessary.
geposted Thu 13 Aug 09 @ 6:17 am
Ahhhhhhhh...NOW I get it, lol. The link was for the latest driver package. Now it all makes sense, hehehe!
I was quite sure that there was no particular firmware upgrade link because the versioning update gets you the whole package ;)
geposted Thu 13 Aug 09 @ 6:24 pm
it still does not work guys. ? i installed it from here
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=30&pid=161&cid=1
and it still wont work.. i need to figure this out asap.. ://
My mixer starts to blink and act like it has a "Short" I have no idea whats going on.. can you guys please help :
geposted Sat 25 Jun 11 @ 12:11 am
You need to select djmusic them controller with audio then hercules rmx then drivers at lease thats how i do my hercules rmx and dj 4set controller, i just update my drivers and got a firmware update for my dj 4 set which now allows me to use the sliders for pitch controll
geposted Sat 25 Jun 11 @ 9:36 am
@Muroanthony626
have you tried this procedure ?
http://ts.hercules.com/faqs/eng/her_eng_00384.pdf
geposted Mon 27 Jun 11 @ 12:52 pm
