hi im running cue 5.2.1
when i load a track now if my pitch slider is physically not at 0 the song that goes loaded displays 0 in the % and i cannot do anything with the pitch until i physically move the slider to 0, then the pitch starts to update.
is there a way to not make it do this?
it just started...
thanks.
it just started...
thanks.
geposted Wed 12 Aug 09 @ 7:42 pm
This is sort of a "safety feature." I think you can disable it by going to config-->options and setting Pitch Reset On Load to "disabled."
geposted Wed 12 Aug 09 @ 7:47 pm
