I need help fast if any one can.. on boat up im getting a black screen thay says not enough space in runtime area!!. SMBIOS data will not be available. Press F1 toresume,,, but nothing happens when I push f1
geposted Wed 12 Aug 09 @ 8:21 pm
I need more specifications of your pc ... brand & model ... laptop or desktop... and if you could take a picture or write the exact error on screen would be better...
Any beep codes from the mother board ? (in case of a desktop)
Im gonna wait... for your answer...
geposted Wed 12 Aug 09 @ 8:33 pm
Still waiting....
if youre using a desktop... you may have the chance to clear cmos using the jumpers (i need the motherboard model to explain)...
i got 3 questions if the problem is on a desktop...
1- did you recently update the lan drivers ?
2- do you have enabled the on board lan on bios settings ?
3- did you recently update your bios ?
geposted Wed 12 Aug 09 @ 9:25 pm
http://vip.asus.com/forum/view.aspx?board_id=1&model=M3A32-MVP%20DELUXE/WIFI-AP&id=20080311015941640
this is all i could find on the problem. I only have a USB cd drive.
ASUS M3a79- t Deluxe
Vista 32 home
geposted Thu 13 Aug 09 @ 10:49 am
i also took the battery out.
and
reset mb defalts
and
reset mb defalts
geposted Thu 13 Aug 09 @ 10:52 am
I would highly recommend having a 2nd backup laptop for this very reason.
geposted Thu 13 Aug 09 @ 1:57 pm
my backup when down due to my RMX not working. this just happened last night.. what next
geposted Thu 13 Aug 09 @ 2:04 pm
I did everything on the thread but nothing is working...
geposted Thu 13 Aug 09 @ 2:07 pm
talked to techsuport.. tried a couple of things that didnt work and they gave me an RMA.. This system is going to be down for a couple of weeks... Back to the My RMX problem.. thanks you for alll the help
geposted Thu 13 Aug 09 @ 4:34 pm
