is it possible to combine Ion Icue with a UC33E on vdj 5? Will it be easy to configure UC33E so that it works for the vdj sampler?
thanks
thanks
geposted Thu 13 Aug 09 @ 5:47 am
Hi c4rashy,
simple no.
The LE-Version is designd only for your controller.
Only with VDJ PRO it is possible to connect any MIDI Controller.
Haui
simple no.
Haui
geposted Fri 14 Aug 09 @ 6:44 am
Hi c4rashy,
simple no.
Haui
can i use both ion icue and UC33E at the same time using virtual dj 5 pro?
simple no.
Haui
geposted Fri 14 Aug 09 @ 2:30 pm
You can use both controllers using a licensed copy of Pro or CUE Full.
You can upgrade at a discount to VDJ pro on this website.
geposted Sun 16 Aug 09 @ 8:50 am
