hey im looking to buy a controller for vdj and traktor...i like using the both softwares....i dont no why....i no there isnt a perfect controller but i want a controller that doesnt have that many downsides or that many bad reviews of it being defective or sumthing like that.....all i wanna do is mix my techno/trance.electro/house, watever.....but its hard doing it all with just the computer....i was thinking of getting the tourq xponent, but i think i heard on a review that its really fragile.....im not a carefull person...lol....
geposted Thu 13 Aug 09 @ 8:19 pm
my best option for you will be Numark total control.
100% compatible with vdj and traktor (plug and play).
the only thing i don't like about it is that is made of plastic, that's the one of the different between the total control and the hercules rmx but
like i said total control is just plug and play while the rmx it's gonna give you a hard time.
geposted Thu 13 Aug 09 @ 9:07 pm
hey thanks for the info really helped alot, and wat do u mean by giving me a hard time??? the hercules
geposted Fri 14 Aug 09 @ 1:10 am
I'm not sure what Azen meant but the RMX is a damn good piece of gear. I bought an RMX for one of my sons and a good friend who has been a DJ for 30 years (DJ Advise) uses one and he swears by it. The Total Control is a nice "entry level" DJ tool but the RMX is a quite a step up from that. It has it's own built in sound card and it's more durable and substantial feeling because it's made of metal. If you are interested in a Numark product that is more comparable to the Hercules RMX then you may consider the Omni Control. None of what I am saying is meant to discredit the Total Control, it holds it's own and is a good product as well.
DJ RuDe
geposted Fri 14 Aug 09 @ 2:05 am
I looked at them all. I picked the Vestex VCI-100.
It's sturdy, totally programable, and has touch sensitive pads. Theoritically it should scratch better than a vinyl time-code because of less mass in the mechanism.
Looked at all the units this week at the AC Expo. I'll keep what I have.
Now if Pioneer would donate to me their $10,000 video setup I wouldn't complain a bit.....haaaaaa. That jump drive input is the it-shay. This would of course be in addition to my prime DJ engine... VDJ on dual PCs of course.
I just wouldn't be able to carry this rig over my shoulder with a gig bag like I do now with my VCI-100....hehehehehehe
hockadeer
Jim-e-L
hockadeer
Jim-e-L
geposted Fri 14 Aug 09 @ 3:20 am
DJ RuDe
.I'm not sure what Azen meant but the RMX is a damn good piece of gear. I bought an RMX for one of my sons and a good friend who has been a DJ for 30 years (DJ Advise) uses one and he swears by it. The Total Control is a nice "entry level" DJ tool but the RMX is a quite a step up from that. It has it's own built in sound card and it's more durable and substantial feeling because it's made of metal. If you are interested in a Numark product that is more comparable to the Hercules RMX then you may consider the Omni Control. None of what I am saying is meant to discredit the Total Control, it holds it's own and is a good product as well.
DJ RuDe
I've seen a lot of topics saying having problems with the rmx. I was thinking on buying one but since nobody can tell me if the rmx is just plug and play besides a lot of user are having problems with it.
geposted Fri 14 Aug 09 @ 8:27 am
DJ RuDe
DJ RuDe
All that and anyone who ever starts in the game with just a computer and controller eventualy you will move twards CD or TT Deks!! Trust me you will!!! The RMX is set up to handle such a transition without having to buy more hardware!! I got rid of mine once and bought it right back!!...lol best investment I made!!
geposted Fri 14 Aug 09 @ 10:38 am
yea guys i think im just gonna start with vdj or any softeware a comp and a controller and slowly get the hang of mixing, and then upgrade to turn tables or cds or watever, oh and one more question, can u connect your cds or tt to vdj or traktor and mix or sumthing.......
geposted Sat 15 Aug 09 @ 6:11 am
DJ Advise aka DJ Mauro just posted this video about the Hercules RMX...
DJ RuDe
geposted Sun 16 Aug 09 @ 4:56 pm
The xponent is not fragile... I have been using one for quite a while on big sound systems and it is a very good controller/soundcard..
geposted Sun 16 Aug 09 @ 11:05 pm
The M-Audio Xponent is alot better than the Hercules.. It has more features and you can scratch where hercules is just for blending. The Xponent has a 10 slot sampler and led lights which is very important when you are mixing.. You need to monitor your mixes so it doesnt come in too high on the blend. The Buttons on the X Ponent are more visible because they light up. The RMX looks nice but it doesn't perform better than the X Ponent. You can do alot more on the M-Audio
geposted Mon 17 Aug 09 @ 2:17 am
DJRudeDoGG wrote :
DJ RuDe
DJ RuDe
He just released part Two!!
DJ RuDe
geposted Mon 17 Aug 09 @ 5:32 pm
