3-lines mixer configuration seems to work only with 6.1 sound card.
i try with BCD2000 and an my laptop sound card.
Configuration :
Inputs : None
Outputs : 3-Line Mixer
Sound Card : 2 Sound carts First :BCD2000 Second : laptop Sound Card
Chanel's 1&2 :Left Deck Chanel's 3&4 :Right Deck Chanel's 5&6 :Sampler/preview
The sampler sound came out correctly from the laptop sound card, but both deck's sound came out from BCD's both output's ,(both BCD's outputs plays the same)
i try 6.01 and 5.0 rev5 versions....same results
So, it is possible the 3 lines mixes configuration with a BCD2000 for deck’s out and a second sound card for sampler out?? ( ...or perhaps with a pair of EKS XP10 and an extra sound card for sampler out ??) and how???
Thanks, and sorry about my bad English….
geposted Fri 14 Aug 09 @ 11:16 am
3-line mixer only works with a single (1) soundcard that can provide 3 outputs.
The 2 sound card setup is designed to providing an independent output for each deck - which is 2 - not 3.
geposted Fri 14 Aug 09 @ 11:34 am
Which Version of VDJ do you use ??? PC or MAC, Home, LE or Professional ?
It would be a good idea to register your version of VDJ with the 'Modify my profile' button and download the installer again. If you try the version 5 then download 5.2.1 from your download center. The version you used is very old !!!
With 6.01 i can not reproduce your problem. I hope you use a official version of VDJ because all the wild 'copies' in the net are mostly buggy and infected by trojans and viruses.
Greets, Heiko
Greets, Heiko
geposted Fri 14 Aug 09 @ 11:36 am
Xm...i thought so.... pity....in a future version maybe .....
Anyway ....thanks for quick and clear answer...
geposted Fri 14 Aug 09 @ 11:59 am
You could combine mulitiple soundcards using ASIO4ALL which might help you get around this.
geposted Sat 15 Aug 09 @ 5:03 am
