I just set up my 2 stanton t80 turntables and mixer to my computer using the maya 44 usb soundcard. I'm using 2 rane serato timecoded vinyls and they get 100% signal using the noisemap system, however i cannot fully control it using my turntables. When i stop the vinyl virtual DJ starts bugging out and it shows the vinyl spinning very very fast and creates an unpleseant noise. Any help would be appreciated.
Sometimes one works but i don't know why and why the other one never does.
geposted Fri 14 Aug 09 @ 2:06 pm
Re-install the maya I had this happen many times..also get the ASIO for all drivers they will help you...Also user a different port and when your done installing do a restart...TRUST me even though it says you dont have to? DO IT!!!...hope this helps...
geposted Fri 14 Aug 09 @ 2:11 pm
where do i get the ASIO drivers?
geposted Fri 14 Aug 09 @ 2:27 pm
HERE
www.Asio4all.com
Hope that helps
www.Asio4all.com
Hope that helps
geposted Fri 14 Aug 09 @ 3:10 pm
I tried everything you said but now both won't work. Before one would work some of the time but now i cant get either to work. Any other suggestions?
geposted Fri 14 Aug 09 @ 4:02 pm
