Hey guys,
I've been trying out a few PC DJ'in apps and im pretty much settled on VDJ....bar one problem: whenever i change the pitch, the beats get distorted and the music randomly slows and speeds up. Not badly but its noticable (even more so when mixing). Now i've had a search through the forums and cant find much. I looked through the skipping thread and have done the things suggested which i hadnt already tried but nothing seems to fix it. Here's my spec if it helps (all drivers updated):
OS: Win XP Pro
CPU: AMD Sempron Mobile 3000+ (1800ghz)
Ram: 512mb
Internal Sound Card: Realtek ALC655 (speaker output)
External Sound Card: Hercules Muse Pocket (headphone monitor)
I'd like to think its not a software problem as this app does eveything else perfectly but i've had no problems with other apps and this is being run on a brand new laptop with a fresh OS install (by me).
I'd appriciate any advice as i'd really like to get the full ver.
OS: Win XP Pro
Ram: 512mb
geposted Tue 12 Apr 05 @ 11:28 pm
beatlock on?
timestreach on?
turn off both, no problems :)
timestreach on?
geposted Tue 12 Apr 05 @ 11:53 pm
Thank you!
Timestretch was killing it.
Sorry that must have been a real newbie question but i honestly couldnt find info on it....should've looked harder.
Thanks again...this software is now perfect :D
geposted Wed 13 Apr 05 @ 12:14 am
good to hear ;)
hopefully you will become full member soon :)
geposted Wed 13 Apr 05 @ 12:58 am
With these complaints of distortion using timestretch, are you all adjusting the tempo significantly?
I beginning to wonder if my ears are bad, because if I keep the stretch to a modest level, I can't hear any of these warbles or claps that are being reported.
geposted Wed 13 Apr 05 @ 10:01 pm
modest level works fine
just like hardware do, like Pioneer players
its extreme that dont sound to good, VDJ or Pioneer, or any other...
geposted Thu 14 Apr 05 @ 4:35 am
