Does VDJ offer the capability to manually fade and go while in Automix? I want to use Automix to automatically load files but I want the ability to manually click on "Fade" and havd VDJ crossfade into the next song.
geposted Sun 16 Aug 09 @ 3:17 pm
You can do this with a keyboard shortcut.
I use the space bar
Set the script for the space bar or key to read autoplay_skip
I use the space bar
geposted Sun 16 Aug 09 @ 4:58 pm
Thanks. I'll give it a try.
geposted Mon 17 Aug 09 @ 8:33 am
Is there also a script, while in Automix, that will allow me to manuallt command VDJ to fade out of the current song, stop playing and make the next song the primary song?
geposted Mon 17 Aug 09 @ 1:49 pm
