Forum: Old versions
Topic: Pioneer CDJ800's & Behringer DDM400
i was wondering im new to virtual dj.. is there a posibble way to connect my CDJ's & Mixer?
what sortware do i need. and if there is any extra stuff needed in order to connect it?
geposted Mon 17 Aug 09 @ 6:54 pm
Your going to need a 4 in 4 out sound card so you can use time code with your CD players and your going to need a midi to USB cable if you plan on using the midi functions of the DDM4000 with virtual dj
Well first your going to need VDJ pro!! Next if your using the DDM4000 that is a MIDI controller and can be used with VDJ with proper mapping. Finally if you are a Pro User you can download XML files that other pro user's made when they mapped their DDM to VDJ
good luck....
