Quick Q
When i am mixing a song from deck a into deck b everything is fine ... however when i mix a song from deck b into deck a, the moment i hit play or Que both songs slow way down, sounds weird for a moment then continues to play...
I've tried everything i can think of...soo any help would just be SWEET.
geposted Mon 17 Aug 09 @ 11:23 pm
Hi,
my first thought!
Soundcard!
What is your setup/specs?
Haui
my first thought!
Soundcard!
Haui
geposted Tue 18 Aug 09 @ 8:08 am
Absolute shit... But i'm getting a hook up this weekend when i get paid. hope that fixes the problem, thanks
geposted Tue 18 Aug 09 @ 1:21 pm
Beatlock enabled?
geposted Tue 18 Aug 09 @ 1:30 pm
Nice words!
Ok, Beatlock is a also a alternative. ;-)
But i remember a user who has also problems with the sound, something simular like you.
Never i would belive something inside his soundcard was damaged, after he changed the channels, the same effect was on the other deck.
Then he changed the Soundcard and everything was OK!
If it was only Beatlock, great!
Haui
geposted Tue 18 Aug 09 @ 1:44 pm
It was beat lock, thank you so much ... Now I can get back to polishin my skillz
geposted Tue 18 Aug 09 @ 2:43 pm
Good good :)
geposted Tue 18 Aug 09 @ 5:05 pm
