I'm not sure if this is related to the beta version of VDJ or just a general issue, but I can't drag and drop a track from Mixshare (RE) to VDJ.
I used both previously on a PC with no problems, but since I got my shiny new macbook pro, I'm having problems.
Anyone use this ... did it work in previous versions?
Thanks
Thanks
geposted Tue 18 Aug 09 @ 12:04 am
Tried both versions. Drag and drop does not work in either.
Bummer.
(works with Traktor though!)
Bummer.
geposted Wed 19 Aug 09 @ 2:34 am
Same problem with new 6.02 version. I can't drag and drop a track from Mixshare.
Very frustrating as that's where I manage my entire library (and check out potential harmonic mixes)
Am I alone?
Am I alone?
geposted Tue 01 Sep 09 @ 9:47 pm
