For effect keyboard shortcuts, I have been setting keys to effect=1 effect=2 and effect=3 (momentarily), which will activate whichever effects are selected under fx for that channel and respective effect position number. For example, if the flanger is selected for effect one, then pressing the key will momentarily activate the flanger effect.
Is there a way to use keyboard shortcuts for more than 3 effects? Maybe a way to shortcut loading a given effect to an effect slot for that channel (e.g. when I press b it loads beatgrid to effect slot 2)?
geposted Tue 18 Aug 09 @ 7:53 am
