i have just downloaded virtual dj n it wont let me on because i have an invalid skin file cud any on point me in the right direction
geposted Tue 18 Aug 09 @ 4:19 pm
Did you have an older version of VDJ loaded on your computer BEFORE this download? Try going into "my documents" and find the VirtualDJ folder. Open the folder and copy the "VirtualDJ Database v#" file and save it somewhere where you'll remember - just in case you need to revert to the older version. Delete the "VirtualDJ" folder, and try reinstalling the newer version. I had a similar problem going from v5 to v6 and I think that did the trick. Hope that helps.
-e
-e
geposted Tue 18 Aug 09 @ 4:56 pm
As above - where did you download this copy of VDJ from - and have you had any iffy version installed previously?
geposted Tue 18 Aug 09 @ 5:12 pm
