Hello,
how do I make new actions available to select from the drop-down lists next to the 6+6 buttons in the RMX skins? This used to be done using djcel's mapper if I remember correctly but no longer seems possible in V6.x
geposted Tue 18 Aug 09 @ 7:43 pm
With V6's mapping features its easy. Config/select device/auto learn.
geposted Tue 18 Aug 09 @ 9:05 pm
Doing that doesn't allow for the flexibilty I'm after, as it means mapping one single command, and only that command, to each button. This is a step backwards from what was possible before. It also results in the skin looking very messy and inaccurate because the buttons mapped to actions wont actually be doing what is physically written on them in the skin.
Is it possible to create sound effect plugin files for actions such a loop in, loop out, loop halve/double? As this should solve my problem.
geposted Tue 18 Aug 09 @ 9:56 pm
