vdj slows the pitch by 10% its ticks me off
im using the ssl vinyl which worked ok in 5.0.7
after that happen i went back to mixvibes
geposted Tue 18 Aug 09 @ 11:10 pm
im hopping this get fix mixvibes does not have a history playlist and i love using it
geposted Wed 19 Aug 09 @ 12:57 am
can anyone help me with vdj ?
im on 6.0.1
im on 6.0.1
geposted Wed 19 Aug 09 @ 1:04 pm
What OS are you using? I have seen this on my friends setup he is using VISTA 64 bit OS I can't put my finger on it? It pisses me off also when I mix with him!!! The only thing you can do that I think of is tweek the pitch seneitivity and lead time...thats in the TC config under the debug tab.....
geposted Wed 19 Aug 09 @ 8:56 pm
im using windows 7
every since i moved to 6.0.1 i have had this prob .
even on vista 64 bit
i have one vdj record i tryed that still does the same thing
my pc spec's or 3.6 core 2 due
950 mhz 8 gb kit
1 ocz 30 gb Vertex ssd
2 Western Digital VelociRaptor 150gb .
1 rme rpm
i feel like vdj was alil better before even tho when the time code does work it feel like the scratching is better in 6.0.1. i hope they fix this .
for now my mixvibes has no bugs so i will have to stick with that .
i love both sofeware's and would love using both at the same time
geposted Thu 20 Aug 09 @ 11:55 am
fixed
turn off clear sound
then install a new mp3 LAME codec in
C:\Users\music headz radio\Documents\VirtualDJ\Plugins
also if your runing 64 bit windows install
http://shark007.net/x64components.html
geposted Fri 21 Aug 09 @ 2:32 pm
http://www.free-codecs.com/Lame_Encoder_download.htm
I already asked to DEV team to keep this codec updated.
geposted Sat 22 Aug 09 @ 6:03 am
