Hi there, I'm a convert from pcdj fx, my question which might sound silly is.
In pcdj fx you had a auto mix feature were you could put songs in to a waitlist a bang it would play till I stopped it eg go off for a pint or a quick smoke outside. Is there such a facility on vdj if so how do I turn it on etc.
I know it sounds silly put it is handy cheers and thanks
Tricky discos perfect sound all events...
geposted Wed 19 Aug 09 @ 11:46 am
All you have to do is....put the songs you want to play in the right side list....In that side list at the top left you will see a round cd...click on the cd....and it will start to play... good luck.... hope this helps!
to get the songs in the side list
click and hold on the song.....then drage the song to the right side list...then drop it in the side list....
geposted Wed 19 Aug 09 @ 12:10 pm
when bob says left he means right, it's the left hand thread they use nick.... lol
geposted Wed 19 Aug 09 @ 12:13 pm
Please see pages 15 and 16 of the user manual for details of how to use automix: https://virtualdj.com/images/pdf/VirtualDJ6-UserGuide.pdf
geposted Wed 19 Aug 09 @ 12:16 pm
Cheers lads managed it, thanks, I think I was being a bit empty headed.
works a treat
works a treat
geposted Wed 19 Aug 09 @ 12:17 pm
I have to put a mark on my right hand...lol
geposted Wed 19 Aug 09 @ 12:20 pm
