Hi all,
In order to save time inserting a cover to a cd,can anyone choose to search for a cover by album title instead of browsing through hundreds of covers (by artist) to find the right cover for your album?
I find it frustrating that the default option to search for any cover is set to the artist instead of the album which should limit the number of clicks to get the right album:).
If anyone knows the answer to my question, i'll appreciate your tip, if not, maybe the developers should look into working on making the cover uploading painless. Don't get me wrong, the future is fantastic and very functional, virtualdjing is all about organizing your playlist or being able to browse through them quickly.
Jolofboy
Jolofboy
geposted Wed 19 Aug 09 @ 4:27 pm
Hi all,
I find it frustrating that the default option to search for any cover is set to the artist instead of the album which should limit the clicks to get the right album:).
If anyone knows the answer to my question, i'll appreciate your tip if not, maybe the developers should look into it.
Jolofboy
Jolofboy
geposted Wed 19 Aug 09 @ 4:41 pm
Hi jolofboy
1. Google the album title, find it & copy cover.
2. if it's an album get a tag & rename program open the album folder.
3. highlight the folder and song files, paste folder and file cover with image you copied
4. Save tags, then in VDJ search for the album highlight song files right click go to file info, then click reload tags.
If you rip you're music in iTunes and then migrate into VDJ
1. Search for album highlight all tracks.
2. Right click choose get info.
3. Paste the image to the artwork box and click ok to write to files.
4. In VDJ follow # 4 above.
5. If it doesn't work click on the album folder on the left panel in VDJ, right click & scan for tags Opt.
Good Luck
Joey.....
Good Luck
Joey.....
geposted Wed 19 Aug 09 @ 6:39 pm
thank you Joey, i am going to try your suggestion and see how it works. Visualizing the cd cover will help find the tracks that i need as i don't remember them all by name.:)
Omar
Omar
geposted Thu 20 Aug 09 @ 4:07 pm
