Hi!
Im using Cue LE with my Ion Icue. Ive heard that VDJ 6 is a very good software, and I kind of want to buy it. Ive seen videos on youtube showing how to do stuff with vdj 6. I saw that it doesnt have the same config menu like the trial of vdj5 that i tried. I inspected it on the forums, and it was approved. Instead a feature called mapping is used. I read pretty much about it.
Now to my question. If i buy vdj 6, how will i get the mapper file for Ion Icue. Will it just be there by default? I checked the Tools section of this site, and there isnt an Ion Icue mapper to download there.
Thanks for any help!
-c4
-c4
geposted Thu 20 Aug 09 @ 9:05 am
Hi c4,
the Ion iCue mapping is native in V6.
As far i can see, the mapper isn't that large then other mappers are. It means, i believe only the basic functions are inside.
But it doesn't hurt, you can adjust the mapper in a easy way up to your choice.
If you have some problems, i'm sure somebody is around to help you.
Haui
Haui
geposted Thu 20 Aug 09 @ 9:41 am
