Hi all,
I was just curious to know if one could listen to a next song from the browser without loading it onto the other deck? It would be a great feature to have, i have tried right clicking and preview, unfortunately there is no sound.
Thanks for sharing your knowledge if you know about this great future.
DJ Omar
DJ Omar
geposted Fri 21 Aug 09 @ 12:31 am
There is a feature for that, I'm not sure about on the LE version but once you upgrade you will find a plethora of nice features unavailable on the LE version. Since you have an RMX you should qualify for a nice upgrade discount.
DJ RuDe
DJ RuDe
geposted Fri 21 Aug 09 @ 2:04 am
Great advice Haui,
I am better of cueing my next song from the other deck rather than trying listening to it from the browser list.
DJ Omar
DJ Omar
geposted Mon 24 Aug 09 @ 1:55 pm
Haui70 wrote :
Hi DJ Omar,
i'm also not sure about the LE version, but when you can activate the prelisten function, you should hear something.
Maybe you must press the PFL Button too?!
At the moment the PRO has a little problem with the prelisten function too.
It can happend, you hear over the PA a crackling noise, when using the function.
So it is better to use the second deck, to prelisten the upcoming track!
See you
Haui
See you
Haui
Pre listen does work, but fast foreward the track youre pre listening to, as it is at that point the main audio screws up.
dosent make us look good when we forget about this nasty bug!!!
+1 to previewing on the 'other deck'
geposted Tue 25 Aug 09 @ 5:47 pm
