Hi guys i am about to order some timecoded vinyls but i have fount there is so many to choose from so i basically just want a bit of help choosing.
Which ones work the best with virtual dj.
Thanks in advance.
Thanks in advance.
geposted Fri 21 Aug 09 @ 4:11 am
Oh and just one more thing what sort of pc spec do i need to be using timecoded vinyls.
Will my spec as follows be ok with timecode vinyls.
AMD X2 6000+ (3.1ghz dual core processor)
3gb ddr2 800mhz memory
geforce 9600gt 1gb video card
1x 160gb hard drive (For windows and VDJ)
2x 500GB Hard drives for Music, videos etc
I am also running windows vista home premium but i will quite happily downgrade to xp if timecode works better with xp.
geposted Fri 21 Aug 09 @ 4:38 am
Serato & Numark are OK (in this order )
geposted Fri 21 Aug 09 @ 4:48 am
i am also looking at 2 sound cards and dont no which one to choose i am looking at either the esi maya 44 or the AMERICAN AUDIO VERSA PORT.
Im not sure which one would be best.
A little help and support would be nice
geposted Fri 21 Aug 09 @ 11:15 am
for the sound card..it depends on your budget buddy...if u are goin for the awesomest thing and best thing.....i would highly sugest the AUDIO8 ut if u are lookin for average ....but still perfect for timecodes i would suggest the ESI u46dj and i vouch by it..ITS AWESOME>..been using it since it came out..loved it...!!!!!
geposted Fri 21 Aug 09 @ 2:16 pm
