I downloaded the trial
It doesnt seem to work I drag a song and it loads it.. but it will not play it
I cannot preview.. or listen to samples
idk if it's the sounds or the software
Can someone please help me?
Thanks
Thanks
geposted Fri 21 Aug 09 @ 4:24 pm
what are your sound settings set to in the config menu? what gear are you using? are you just using the software? the more info we get, the easier it is to help you.
Michael
Michael
geposted Sat 22 Aug 09 @ 7:04 am
Check your sound card settings - sounds like you might not have this working right.
geposted Tue 25 Aug 09 @ 1:43 pm
