why some of my itunes music doesnt play on virtual dj it just says "ERROR"
what can i do?
what can i do?
geposted Sat 22 Aug 09 @ 3:22 am
Upgrade the songs to iTunes plus.
geposted Sat 22 Aug 09 @ 9:51 am
Hello sergio_gio,
If the iTunes music files you cannot play on VirtualDJ are music files you have bought on iTunes, then it is likely they are files with DRM (Digital Right Management) and you cannot play them in any software except iTunes. A workaround solution consists in burning a CD audio with these files in iTunes and mixing this CD audio in VirtualDJ.
If the iTunes music files you cannot play in VirtualDJ are music files you imported in iTunes, then you should check you iTunes import settings (in iTunes > Edition > Preference > Main > Import Settings, and choose an import format for which you have a codec on the with VirtualDJ.
geposted Tue 25 Aug 09 @ 8:41 am
You could also try using TuneBite to convert these files to WAV/MP3, and then play them through VDJ.
geposted Tue 25 Aug 09 @ 8:44 am
SoundTaxi also works well - i convereted my entire iTunes db last year and it worked great. The pro version has a YouTube ripper too to extract Audio and/or Video. (From Internet Explorer only) http://soundtaxi.info/
geposted Wed 26 Aug 09 @ 7:34 am
what can i do? I have tried importing the music in different formats but still nothing.
Any suggetions?
Any suggetions?
geposted Thu 24 Sep 09 @ 2:59 pm
The best solution : switch sound file converter
geposted Thu 24 Sep 09 @ 5:59 pm
