I have a laptop and a rackmount running at most every event, with the rackmount acting as the primary system. When I do bars I'll bring just the laptop and play off that. Is there any way to sync the database between the two systems so that if I set cue points on one they show up on the other?
geposted Sun 23 Aug 09 @ 7:15 am
As long as the directory (and file structure) structure of your music is exactly the same. All you need to do is copy [My Documents]\VirtualDJ\VirtualDJ Database v#.xml to the same location on your second machine.
geposted Sun 23 Aug 09 @ 9:30 am
