I guess it´s not possible to record and export a mix as mp3 file in Virtual DJ.
Wich program can I get right now to do it? Got a big party inc and I need to have some sweet mixes rdy.
Cheers!
Cheers!
geposted Sun 23 Aug 09 @ 8:49 pm
Cheers!
Cheers!
You can but you won't be able to use your external mixer unless you MIDI- map it and that will only work if you have a MIDI-mixer. You're better off recording into a stand alone recorder from your mixer's REC out jacks, which is what I do.
DJ RuDe
geposted Sun 23 Aug 09 @ 10:14 pm
