the DN-HC1000S from Denon AND THE Denon DN-HC5000 i think the HC1000 in not needed they should just make an upgrade of the 4500.here some link for the two items http://www.djzone.net/pg/news/gear1/denon-dn-hc5000-released-at-dj-times-dj-expo.shtml
geposted Wed 26 Aug 09 @ 2:08 am
The 1000 is a controller for serato to access your library & Cues. You press the buttons to access your 1 thru 5 cue points, Scroll crates & songs. The HC5000 is an example of the Hc4500 with the 1000 controller built in. The only thing is .. its designed for serato itch.. Over all, The Hc4500 has a better layout.
geposted Wed 26 Aug 09 @ 5:43 pm
The HC1000S can be used and mapped with any software.
geposted Fri 28 Aug 09 @ 12:44 am
DEAR MR DENON DJ - hows the fixes on the s3700 going -- can you let me know if the midi and platter issues have been resolved.. would love to be able to dj with vdj and have a backup cd in there in case of a vdj problem
DJ Jamm
DJ Jamm
geposted Fri 28 Aug 09 @ 1:57 am
Its Not Denon.. There is nothing wrong with the 3700's. There is something wrong when you use it with Virtual DJ. You have to wait for the Next update which is soon.
geposted Fri 28 Aug 09 @ 11:14 am
