Hi everyone!
I have been looking for old Firmware versions of the numark axis 9 on the internet but cannot find any!
The only available is the actual new from the numark homepage.
but i want to try and old one, because since i installed the new one i got some issues while using them.
So if anyone has an update history, please post the links here so i can download the old ones and try them.
or does anyone know how to reset the Axis 9 to the delivery status?
Thx
Thx
geposted Wed 26 Aug 09 @ 3:28 am
What issue do you have?
geposted Thu 27 Aug 09 @ 6:11 am
well they didn't seem so interested, although I am concidering trying another cd burner unit,
I myself was planning to reinstall an older version so that the latest version could be installed with a slowly burnt update cd as the device I'm currently trying to update is playing burnt cd's but with added white noise thats not really what I'm after tbh,
I have looked about the forums etc for an archive of the previous versions although there seems to be little advice appart from buying newer appliances, I fear that there is no other way to restore the original firmwire via start up commands
and as I say I was unable to find a version of the firmwire earlier that version 38 r6 , any ideas greatly recieved! ;]]]
geposted Mon 30 Apr 12 @ 1:54 pm
This thread is nearly 3 years old and the Axis 9 is a discontinued product.
It may be best if you contact Numark directly for support.
http://www.numark.com/support/customer-care/gb
Topic locked
Keith
Topic locked
Keith
geposted Mon 30 Apr 12 @ 2:03 pm
