Hello!!
I been tryin to record a video mix, but vdj keeps tellin me **error found** video codec not found.
where can i get the codec and what kind of codec is it? please help! i been tryin to figure this out for awhile.. i know some one might of had the same problem i just havent found a post with that info. thank you very much.
oh yeah!! i have xp system!
geposted Wed 26 Aug 09 @ 11:52 am
search the forums there are several post regarding this problem and the solution.
geposted Thu 27 Aug 09 @ 7:19 am
you could try downloading the k lite pack of codecs...
geposted Thu 27 Aug 09 @ 5:38 pm
what codac is the essential for recording video? i download the mpg4 codac and still nothing.
geposted Thu 27 Aug 09 @ 10:31 pm
ok i think i got it, but when i press record.. all it says is waiting to start.. when i press play on the turntable. vdj wont record anything.. it just keeps sayin waiting to start.
geposted Thu 27 Aug 09 @ 10:58 pm
You can disable the auto start feature by clicking on config (on the recording tab) then unchecking auto start.
geposted Sat 29 Aug 09 @ 7:51 am
