Hello
I was online and found this thing looks ok I guess. Anyone up on it?
they say it has a CD Direct outputs for use with time coded systems
Features:
Scratch, brake and reverse DSP effect
Compatible with CD, CD-R, MP3 with full DJ control
Supports multi-partitions for external hard disks (FAT 16/32)
Built-in tap beat (BPM) counter
Slot-in type CD mechanism
CD, USB, SD/phono/line/mic input
Two universal slot and Two universal USB+SD port
Full viewing direction display with ID3 Tag Folder Search
Pitch VR adjust the desired speed
Folder and track encoder selection
Seamless loop
20 secs. anti-shock system
Control function button: open/close, play/pause, cue, search ±, time, single/continue, scratch, loop/reloop (in/out), pitch ± (16%)
Crossfader control CD play and pauseSingle/continuous play mode
2 channel RCA master output / 2 channel REC output / 2 channel XLR output
2 channel Mixer and 3 band EQ control
http://www.sixstardj.com/madcallinone1.html
Features:
Seamless loop
geposted Wed 26 Aug 09 @ 12:16 pm
