hi i got my copy of vdj6 pro last week and have found the forums to be very helpful. I have been a mobile jock for five years but all this virtual stuff is new to me i wish to know which desk top control is good and as i wish to go into club djing i have been told i need a soundcard as well....... can anyone help thanks
geposted Thu 27 Aug 09 @ 12:31 pm
It all depends on what you want to be able to do.
Based on what you have said above, i would suggest the Hercules RMX. Lots of excellent reviews on this site. It has the advantage of a built in sound card, thus meaning you won't need a seperate one.
geposted Thu 27 Aug 09 @ 1:06 pm
thanks will look in to that
geposted Thu 27 Aug 09 @ 1:28 pm
can agree with dan on that, does the job you pay for, would also suggest getting a simple back up soundcard for emergencys if you go the rmx route.
geposted Thu 27 Aug 09 @ 1:47 pm
Have been using the RMX as well and have been very happy with it.
If you haven't already purchased one, I would recommend getting a good ground-loop isolated as well. Well worth the small investment! This gets rid of the hum you may find using a laptop-based DJ solution.
geposted Thu 27 Aug 09 @ 2:00 pm
+1, the RMX is a great DJ tool check out http://www.youtube.com/djadvise DJ Advise has a series of videos onthe RMX with VDJ
DJ RuDe
Keep Spinnin'!!
DJ RuDe
Keep Spinnin'!!
geposted Thu 27 Aug 09 @ 2:17 pm
I have virtual dj 5.0 i maid a mix on it with splits.Wen i transfered it to nero 6.6 it have about a secound delay in the mix what am i doing wrong..
geposted Thu 27 Aug 09 @ 5:24 pm
could be the settings on nero, you can adjust at the beginning before burning.
nb, try opening your own thread if different from original poster, you will get a quicker reply with a better response to your question.
geposted Thu 27 Aug 09 @ 6:43 pm
just like to say thanks for everyones comments
geposted Fri 28 Aug 09 @ 12:40 am
And welcome to the PRO world JAM.
Nice move indeed.
Nice move indeed.
geposted Fri 28 Aug 09 @ 1:47 am
