Hello, i recently got a new laptop which is running on vista. Is it possible to install virtual dj 3.4 or the higher version 4?
Obviously i had these programs on my old xp originally and they worked perfectly, but hope they are compatible with vista.
Many thanks for any help...
geposted Fri 28 Aug 09 @ 10:34 am
4 will work fine on Vista, not sure about 3 though, but you should be fine.
geposted Fri 28 Aug 09 @ 12:51 pm
There is an update for the v3.4 DJ Console Edition to make it compatible with Vista.
You can download this from the Download Center: https://virtualdj.com/download/updates.html
Make sure that you have the latest DJ Console drivers installed: https://virtualdj.com/wiki/Common_Device_Drivers.html
geposted Fri 28 Aug 09 @ 1:32 pm
Hello, thanks for the replies guys, most helpful indeed.
Thanks!
Thanks!
geposted Sat 29 Aug 09 @ 12:46 pm
i just buy the omni control and install on my windows XP 32bit home edition, driver 2.8.17, it always cause my windows serveral times restart when boot up ,and finally boot up then virtual DJ have diffculty to detect the mapping audio no problem, once i rescan it cause virtual DJ shun down, somebody pls advise urgently thks
also how do i play the video file and control the audio sperately (that mean the video will play in full but i still can maniplated the audio level fader
geposted Sat 29 Aug 09 @ 2:11 pm
Hello, just to be sure before i install the driver update. Is it the 2nd one down in the list?
Thanks for any info...
geposted Mon 31 Aug 09 @ 11:23 am
