need help on how to display the artist with song. it seems that only the title of the song is being displayed but not artist. How can fix this problem?
geposted Fri 15 Apr 05 @ 5:29 am
VDJ uses the filenames to display the artist and title columns.
Use the new parser to avoid problems with the "-" character.
This way you can rename like this:
"Artist - Title.mp3" (for example)
(You can use a software to rename all your files from the tags info.
You can also use the ID3tag parser but it slows down.
geposted Fri 15 Apr 05 @ 6:56 am
