Hi,
I just installed the latest version from version 5. How do I get the hercules MK2 to be recognized? It does not work now.
Bill
Bill
geposted Sat 29 Aug 09 @ 11:43 am
You must install the latest drivers from the Herkules website.
Greets, Heiko
Greets, Heiko
geposted Sat 29 Aug 09 @ 11:45 am
Hi,
The sound card works but the other functions do not work. Do I still need the drivers?
geposted Sat 29 Aug 09 @ 12:35 pm
Yes - the controller only works when the driver tool (bottom right in the tastlist) is running. Herkules use a combination of MIDI and HID for the controller so without the software it could not work. (AFAIK)
Greets, Heiko
Greets, Heiko
geposted Sat 29 Aug 09 @ 12:43 pm
Do I need new drivers for the Numark DMC2?
geposted Sat 29 Aug 09 @ 1:29 pm
I have uses the Hecules just to use the fader and headphones. Now I can't get the headphone cue for both decks. I had it set up before that when I touched a wheel on the DMC2 that song would be played in the headphones. how can I get this back?
geposted Sat 29 Aug 09 @ 2:27 pm
I am going back to VDJ 5. The headphones will only play 1 deck through Hercules and The Numark DMC2 is not acting correct.
geposted Sun 30 Aug 09 @ 1:21 am
Did you install the latest update for VDJ 5 (5.2.1)?
For the DJ Console MK2, the audio configuration should look somehting like this :
- Input : None
- Output(s): Headphone
-Soundcard: DJ Console Mk2
be sure to check the box "Apply EQ on external sources"
Then you shodl be able to use the Headphone selector on the front of the MK2 to switch between Deck A, B or the main Mix.
- Input : None
geposted Mon 31 Aug 09 @ 11:57 am
