Im new too VDJ and have a problem that hopefully is just me being thick...
I am using 2 dns 3700's with timecode and vista.
When I load and play the track it runs at nearly double the speed...The bpm is being showen as correct but the track is running fast...
geposted Sat 29 Aug 09 @ 1:43 pm
It depends on setting of your sound card.
Put the Sample Rate on 44.1 KHz instead of 96 KHz.
geposted Sat 29 Aug 09 @ 2:35 pm
Yeah I have it at 44 but still the same problem
Doesnt make sense at all......
HELP..
HELP..
geposted Sat 29 Aug 09 @ 2:50 pm
And why are you using the 3700 with Timecodes ... use them as a controller in MIDI mode ... you will have way more access and control of the software.
geposted Sat 29 Aug 09 @ 3:04 pm
Right...
Ive decided to get my pc hooked up and try and hook up through midi..Everything seems fine apart from I get the odd spike in sound while playing the tracks..
The cpu usage guage up in the top left is very near the limit and I was wondering if this has anything to do with it?
Im running on xp now with 3ghz and 1 gig of ram...
geposted Sun 30 Aug 09 @ 5:33 am
And what other applications do you have running in the background ? Anti-virus? Wire-less adapter? etc.
geposted Sun 30 Aug 09 @ 8:48 am
i gig of ram. you should max out your ram ALWAYS on any gig machine. 1 gig is barely minimal specs. shit vista alone needs a gig ish to work right.
geposted Mon 31 Aug 09 @ 7:28 am
Ive purchased a new machine with quadcore processor and 8 gig of ram....
Hopefully that should sort the problem....
p.s the wife's going to kill me....
geposted Tue 01 Sep 09 @ 5:05 am
what for?
did you change your system only because I had problems with speed of tracks?
geposted Tue 01 Sep 09 @ 1:58 pm
I decided to purchase a new pc because I hooked my 3700's through midi mode and my current setup couldnt handle it....
My cpu was maxed out as soon as I turned on the 2nd platter....
I was well over due an upgrade and this just settles it for me...
geposted Wed 02 Sep 09 @ 4:59 am
