i cant set it up right iselect one time code external mixer and sl1 sound card and it wont work any ideas?
geposted Sun 30 Aug 09 @ 2:41 am
Try to post your settings and you will help us to understand what the problem is.
geposted Sun 30 Aug 09 @ 5:30 am
Yeah, tell us what you have and how you set it up. I have run 1 timecode for years until I broke down and bought my 2nd deck.
geposted Sun 30 Aug 09 @ 10:52 am
i dont know how to show u guys my settings can you post yours?
geposted Sun 30 Aug 09 @ 11:01 am
Just go through each of the Sound card, Performance, and Timecode config areas and write here what settings you are using ...
geposted Sun 30 Aug 09 @ 11:14 am
i dont get a time code signal
but if i use two timecodes i get a signal
problem is that one turntable broke
inputs single timecode
outputs external mixer
soundcard sl1 box
geposted Sun 30 Aug 09 @ 11:38 am
Ok, that is the sound card tab ... what about the other 2 I listed ?
geposted Sun 30 Aug 09 @ 11:53 am
latency 512
safe mode checked
overclocked checked
lowpass filter
filter taps 11
scratch
qualty checked
enhanced alogram checked
filter size 11
master tempo fast
i get no signal with one time code but they work in two timecode setting evrything is normal if i use two timecodes
geposted Sun 30 Aug 09 @ 12:12 pm
Are you sure your table is plugged into Side A (or whatever it may be called) on your sound card? I had that happen to me once. I had a single timecode, but had it plugged into Deck B of the soundcard.
geposted Sun 30 Aug 09 @ 12:52 pm
i will try that thanks i will let you know
geposted Sun 30 Aug 09 @ 6:09 pm
sphis
big thanks that worked
geposted Sun 30 Aug 09 @ 8:43 pm
