Hi all! When i play a song on deck a, and the beatmatches it with deck b and want to make a loop with 4 beats, even though its beatmatched it goes off beat and sounds terrible.
Someone knows whats wrong?
geposted Tue 01 Sep 09 @ 4:22 pm
Hi,
I would check that 'smart loop' is enabled for both decks.
If they are, then vdj did not detect the right BPM of the song, or then the file is encoded in vbr instead of cbr, which in some cases cause the problem you are having.
All of theses scenarios are possible, so you need to make a little testing yourself to find out what's wrong.
geposted Wed 02 Sep 09 @ 5:47 am
Yeah, i tried it but it didnt work. vbr? cbr? is there anything i can do about these things? hard to make loops when they dont fit :(
geposted Wed 02 Sep 09 @ 3:33 pm
