Hi,
I want to have the following setup as I had in VDJ5.
When I moved the jog wheel on the Numark DMC2 controller it would cue that song in the headphones. Pause it would scratch. Play it would speed up or slow down.
Help me Map this.
Help me Map this.
geposted Wed 02 Sep 09 @ 1:59 am
If I move the Jogwheel of Deck A - I want to hear the song in Deck A.
If i Move the jogwheel of Deck B - I should hear that song.
I can only get one deck to be heard. I am also using theHercules MK2 for the headhones and the fader.
geposted Wed 02 Sep 09 @ 2:10 am
try posting this question in the Hardware forum..
I even have a DMC2 mapping thread happening there if you want to add to that one..
geposted Wed 02 Sep 09 @ 10:35 am
For pitch bending, please ensure that the WHEELMODE button is in jogwheel mode (LED off.) You can adjust the jogwheel senstiivity in CONFIG -> Options
For the pre-listening, try changing the jogwheel mapping to the following:
jog_wheel & select
jog_wheel & select
geposted Wed 02 Sep 09 @ 12:32 pm
