I have been working with 6.02 and it has been a mess. I had 5.2 pro working perfectly. My problem is now everything is skipping every 5 - 10 seconds. the music will jump and the cursor will jump. How can I fix this?
geposted Wed 02 Sep 09 @ 5:19 pm
I have Wimdows XP and back to using 5.2 pro.
What is causing this skipping?
geposted Wed 02 Sep 09 @ 5:39 pm
Anyone? I have a job tomorrow and i got to get this fixed.
geposted Wed 02 Sep 09 @ 6:28 pm
are you using time codes
geposted Wed 02 Sep 09 @ 9:16 pm
No, It is skipping in Windows Media also. It is a windows XP issue somewhere...
geposted Wed 02 Sep 09 @ 9:31 pm
I got the skipping to stop, but I can't figure out what is running even after I have every possible program off. The CPU bar is showing bursts of some activity.
geposted Thu 03 Sep 09 @ 12:16 am
I think you are having problems with your latency. There was a program on some thread that I saw, i think it was called DPI Latency checker? it shows how much latency your comptuer can handle. Try searching latency checker in one of the forums.
geposted Thu 03 Sep 09 @ 5:12 pm
How much RAM have you got in your pc?
geposted Fri 04 Sep 09 @ 8:52 am
