i think i seen a post for this before but i can not find it with the great search feature. sorry for double posting. i have been using my zero 4 out live and decided to use my total control for studio midi. well i was playing with it in cue on my editing tower and i noticed a low rumble after i moved an eq knob. from then on it would rumble with jog wheels, knobs anything until i restarted the program. disable and enabling didn't work. the tower is running windows 7 with quad core and 8 gigs of ram. any help would be great.
geposted Thu 03 Sep 09 @ 8:30 am
Try do disable Safe Mode
geposted Thu 03 Sep 09 @ 9:41 am
dagnabit its always the little shit you forget on a reinstall. that did the trick. thanks.
geposted Thu 03 Sep 09 @ 10:07 am
