Hey guys,
Am looking at getting a midi controller to use. Am currently coming out my Mac into Numark DJ IO then into a numark mixer. Obviously with a contoller would be able to cut out the DJ IO and controller.
Have been looking at the Hercules RMX and the Numark Omni. Just wanting to know which one you guys think would be better as both seem pretty much the same.
Currently i only mix audio no video at moment but that might change in the near future.
Cheers guys.
Cheers guys.
geposted Sun 06 Sep 09 @ 12:10 pm
Its a coin toss. Both solid controllers, with almost identical specs....no bad decision here.
geposted Sun 06 Sep 09 @ 12:16 pm
+1
Like Terry said, either one is good.
geposted Sun 06 Sep 09 @ 12:18 pm
chrispk wrote :
Am currently coming out my Mac into Numark DJ IO .
If you already have a external soundcard why don't you look at the Hercules Steel or the Numark Stealth. Both have the same controls as there bigger brothers but they come without the internal sound card.
Also it will be slightly better on your pocket ;)
geposted Sun 06 Sep 09 @ 1:45 pm
Do you want to flightcase it? if not go for the Numark
geposted Sun 06 Sep 09 @ 1:58 pm
Can u run TC Vinyl thru the Omni control? Then I may get that over the Herc.
geposted Sun 06 Sep 09 @ 2:32 pm
Not to my knowledge but, you can do so with the RMX.
geposted Sun 06 Sep 09 @ 2:39 pm
Ok thanks for that might think will go for either the omni or rmx as wanna take as little as possible. Not that the DJ I is that big but hey.
geposted Sun 06 Sep 09 @ 3:19 pm
