I have started to rip my karaoke discs with TriceraSoft to MP3 CDG zip files. VDJ will play and find the MP3 no problem, but not the CDG file. What am I doing wrong?
geposted Mon 07 Sep 09 @ 1:18 pm
Hello ManiaDJ,
Look to the right of the search field the second round button over to the right next to where the amount of files that you are viewing. Its called View Options right click on it and make sure that Show Karaoke is checked. I hope that will help you.
Good Luck,
Keivan
Good Luck,
Keivan
geposted Mon 07 Sep 09 @ 2:35 pm
Yup that is checked. And show video. I have tried with the screen extended to my LCD screen and also without it extended with just the pop-up box in VDJ.
I can see the songs in the list and play them just like a regular song. No problem there. But the "words" (video) don't show up on the other screen. The VDJ logo is there, but nothing else.
My songs are ripped to a zip file which contain an MP3 and a .cdg file. Isn't VDJ supposed to just recognize them? Or is there a setting somewhere that I am missing?
Under the "video" tab I have it enabled and the correct monitor chosen, as I mentioned I can see the VDJ logo on the second monitor.
Am I supposed to see the video files in the list where I see the songs?
geposted Mon 07 Sep 09 @ 2:46 pm
I have done a few videos on karaoke for VDJ including a series on the proper and surefire way to rip CDGs to files playable in Virtual DJ. I use different software than you, try it using the software I use.
Karaoke & Virtual DJ (General Information
Tutorials on Ripping CDGs
Part 1
Part 2
Part 3
Part 4
I hope this helps!
DJ RuDe
Keep Spinnin'!!
geposted Mon 07 Sep 09 @ 3:33 pm
