I know the new mapping system is supposed to be easier.. and I am trying..
But, I can't get the jogwheel to work right.
In VDJ 5.2.1 - I had it mapped as jog wheel (*10) on deck 1 (or jog wheel (*10) on deck 2)
In VDJ 6.0.2 - I can't get it right.
Vinyl Mode - turned off
Key - SEEK
Jogwheel -50 or Jogwheel +50 does what I want.. but it only goes in one direction. I want it to go in which ever direction that I am moving the wheel - like it did in 5.2.1
Any ideas?
Key - SEEK
Any ideas?
geposted Mon 07 Sep 09 @ 5:46 pm
Try using the jogwheel sensitivity adjustment sliders in CONFIG -> Options
To modify via mapping, use param_multiply, e.g:
...Will double the sensitivity.
param_multiply 200% & jog_wheel
geposted Mon 07 Sep 09 @ 7:26 pm
