..Can anybody tell me how to search a specific folder on a hard drive? I have an external drive with all my media on it, with seperate folders for Music, Music Videos, Karaoke...etc...etc..... When I select the karaoke folder in the tree-view on the left I cant type anything into the search box, I have to actually select a folder inside the Karaoke folder (i.e. SFMW069) before it will alow me to search.seeing as I would'nt know off hand which track is in which folder its not much of a help, and seeing as I have 16000 karaoke tracks I could spend all night looking for one track! Any help is appreciated, thanks.
geposted Tue 08 Sep 09 @ 2:30 pm
All you need to do is right click on the folder that you want to add and then in the fall down menu, click "add to search DB". It will search that folder in addition to your other folders, whenever you do a search for a song later.
geposted Tue 08 Sep 09 @ 3:56 pm
I agree with nsxmarv...Have you added all of your folders to the search DB? It may take some time to do (it did for me), so I'd advise not doing it at a gig. Give that a shot, hope it helps.
-e
-e
geposted Tue 08 Sep 09 @ 6:03 pm
Thanks Guys, I'll give it a go
geposted Wed 09 Sep 09 @ 9:36 am
