im using 6.0.2
and it works fine the first 30 minutes then after a buzzing sound....what settings should i use?
my laptop is
asus m70vm
t9600 dual core
4 gb of ram
nvidia gt 9650 1gb dedicated
1 tb 7200 rpm hardrives (2 500's 7200 rpm 16mb cache)
also i use an external hardrive thats 2tb full of videos and when i do searches it freezes for atleast 2 minutes.
my laptop is
asus m70vm
t9600 dual core
4 gb of ram
geposted Tue 08 Sep 09 @ 4:01 pm
Hello DJ Pancho,
For the buzzing sound, have you disabled the Windows settings authorizing the computer to cut off the USB bus power?
- Right click on MY COMPUTER icon on your desktop and select Properties.
- Select the Hardware tab (Windows XP), or in the Left–hand section (Windows Vista), click on Device Manager.
- Under Universal Serial Bus Controllers, Double-click on USB root hub.
- In Power Management tab, uncheck 'Allow the computer to turn off this device to save power'.
- Repeat the same operation for all USB root hub.
geposted Wed 09 Sep 09 @ 10:18 am
Made In Breizh wrote :
Hello DJ Pancho,
ok i will try it...thanks...
geposted Thu 10 Sep 09 @ 2:19 pm
check it and no dice...still same problem....are there certain settings i need to change on virtual dj?? anyone?
geposted Thu 10 Sep 09 @ 3:05 pm
