I currently use m-audio torq with conectiv vinyl control, however torq does dont support shoutcast. I am looking at getting VDJ6. My question is will it work with my conectiv and also which vinyls will work. I hear scratch live will but wanna make sure it will with all the mismatch brands.
geposted Wed 09 Sep 09 @ 11:57 am
You can use the Connectiv with Virtual dj, It works great. For time codes, get serato. Great needles to use would be The Ortofon OM Scratch or the Shure M44-7 needles. They both give a high output for time code quality.
geposted Wed 09 Sep 09 @ 5:32 pm
Great. thanks for the help
geposted Wed 09 Sep 09 @ 6:48 pm
